I need to adapt a 4 pole 220v to a 3 pole 220v plug. This is to run my air compressor off my welder/generator. The welder has a 4 pole 220v plug, (2 hots, neutral, ground) the compressor has a 3 pole plug(2 hots and a ground). I'm thinking that all I need to do to make this work is to just use the 2 hots and the ground from the 4 pole(not using the separate neutral) and attach them to the 2 hots and ground on the 3 pole, and it should work.
Any other thoughts on this, maybe from an actual electrician?
The reason for this is that our house is 50 years old and has limited capacity for any more electrical load, or space for new breakers.
Thanks,
John
Thanks,
John
