Hey yall!! Well, today was a whopping 62 degrees with driving winds and cloudy skies here in Ohio, but I didn't mind. When I got home from school today, I went out to work on this project. I dragged out my little three-ton jack, torch set, 1/2" kobalt sockets, and put in my ipod, and then just started digging into things, following GordoSD's advice...
And I got way farther than I thought I would. I pulled off the front wheels and be-headed the last of the fender bolts, drained the radiator and removed that, and just in general started pulling things off the truck. I don't know what 90% of this stuff is, but I know its not part of the trailer, so off it goes. This is how far I got before I started getting hungry, and it started getting dark outside:
And I busted loose the two rear cab mounts while I was at it. Nothing special, just a breaker bar and pipe over it. I got one fairly loose, and then it just started turning, making this grinding/rubbing noise, so I stuck my jack under the body and jacked it up some, and this is what it looked like:
So, I'm fairly certain that it came loose....
But, if the other three don't let go as easily, should I torch them?? The one that came off is closest to the gas tank, and all the fuel/brake lines appear to be on the driver's side of the truck. I guess if all else fails, I should be able to torch the mounts on the passenger's side?? Idk...
And tomorrow, My goal is to cut the frame and pull the cab off, so that I can take it in as scrap bright and early on Saturday morning, and order steel to build this on Monday afternoon. I'm planning on trying to not spend much out of pocket on this project, because I'm saving up for a real drill press, and a spring break trip I'm going on later in April, so the more stuff that I can haul off to the scrap yard, the better.
I'm also not sure what to do with the engine. Its a 2.8 v6 with attached 5 spd, all with 327,000 miles on it. I don't imagine that many people would want to buy either, so maybe I'm better off just hauling them in, than listing them on craigslist and dealing with tire-kickers, low ballers, etc, to in the end, get scrap price for this stuff. Any ideas??
Well guys, thanks for reading/watching/etc. To everyone who wonders "Why", well, why not?? Haha, its a cool project that I'm making out of something that would just head off to china if I weren't doing this with it, and besides, its actually really fun, once you get into it. And, i'll have a trailer to use, that works really well for my purposes and is something that I can point to and say "I made that", which is a feeling that you can't buy. And, its welding practice for me. Today at school, I started messing around with 3/16" 6010s, about 180ish amps, and that was great. I really like to weld, so why not turn that into something productive, and I'm definatly learning a lot about trucks/trailers/layout as I go. And to everyone else, thanks for the kind words of encouragement. Especially the nay-sayers, they're really encouraging, regardless of what they're trying to be.
