Without pictures this might be tough to describe but I will do my best and post pictures when I can (busy week).
The backhoe on my 202 Massey Workbull attaches to the loader frame on the bottom by a beam slung under and bolted to the front end loader frame. The top link comes down at an angle and attaches to a point just behind where the loader frame goes up to accept the front end loader arms.
Right behind the top link attachment point a stress crack has developed, well re-developed, someone had fixed it before. I took the backhoe off last weekend, removed all the necessary brackets so I could get to it and ground down the old weld and re-welded it. After using the loader and backhoe a few hours this week I noticed it's cracked again. Now the loader frame is what holds the hydraulic fluid and I saw some seeping out yesterday so I have to fix it.
I started with 6013 for an initial pass with better penetration and then ran 4 passes of 1/8" 7018. It looked good, I ground a bit off to look for porosity and the weld was nice and solid. I am wondering if the problem is the weld is flawed, if I should use a different rod or if I need to add some bracing. This is a pretty high stress connection so I am thinking about adding some sort of brace.
I'm just re-reading this and thinking I will have to add some pictures.
