Indiana Ken
I need some education:
I have been following another post, "Motor Amp Draw by Terry G, 7/6/12" and got curious what the power factor would be when running a fractional horse power motor. I have a small bench top grinder and decided to check it using a "Kill A Watt" meter. The label on the grinder indicates 3.2 amp at 120 volt.
The "Kill A Watt" meter readings with the grinder running unloaded are as follows: volts = 119.2, amps = 2.77, hertz = 60, PF = 0.55, watts = 181.
Question:
119.2 volts times 2.77 amps = 330.2 watts. This should be the actual power usage rate as billed by the electric utility....correct? 330.2 watts times 0.55 PF = 181. watts; what I don't understand is why would a meter read in watts based on a PF of 1.0 when the PF is 0.55? What am I missing here?
Question:
