11 spline blade hub/ stump jumper
sotxbill
looking for a blade bar, stump jumper blade hub or blade pan for a 11 spline shaft rotary cutter (brush hog/shredder). Its 11 and 11.
Can fine lots of 12,15 and some 18 spline, but apparently this 6 foot rotary cutter is older or weirder. Gear Box is side mounted like an older bush hog.
Good luck, 11 spline is definitely old and I'm not sure if it was even popular back then.
I had an old IMCO given to me, the guy hit something solid destroyed the blades and bent the stump jumper. He bought new blades not realizing the stump jumper was bent and couldn't find a replacement. I had a good used 12 spline stump jumper so I bought a 12 spline gear box. I probably wouldn't have fixed if it wasn't in great shape otherwise.
I realize it's been nearly 3 years since the original post...any luck with anything? I am also in need of an 11 spline. Actually, my blade bar/stump jumper is repairable but can't find the correct blade bolts anywhere.
Welcome to the forums.
You would help yourself by starting your own post and fully describe your needs. This site uses two different views. Modern View brings old posts to the "top". People using Modern view will see your post and the original post you are tagged onto, so they see the "whole" story related to your post. People using the Classic view only see your post as a reply ("Re") to the original post, if they see it at all, none of that original post shows since Classic does not bring old posts to the top like Modern does; they stay in the list where they were posted in time, where as your post shows as current. When I looked on Classic this discussion is on page 15, buried in the past. People, using Classic, can swap over to Modern to see the original post, but likely many will not bother to do that.
My suggestion is as I posted before. Give DN Equipment a call. They have parts for a lot of different brands. They have helped me out on a couple things I was having trouble finding.
http://www.dnequipment.com/store/pc/viewBrands.asp
