8N and TO20 front steering box???
BLW
hi guys and gals I need some info and this site works I need to check the oil and or grease in the steering box on both an 8N and a TO 20 and can't find in my book how to check it and how to add grease and what weight oil or grease help need info thanks
BLW........there are 2-variants of 8N steering gear boxes. Early one is fairly obvious pipe plug. Later 8N steering gearbox is "secret". Remove the righthand aft battery sheetmetal bolt to the steering gearbox and there is a HOLE down at the bottom of the bolthole. You doubt? Probe with a piece of bailin' wire.
Recommend 2-tubes of sticky corn-head grease from John Deere 'stedda' 90wt gear oil fer either gearbox. Gear oil leaks, corn grease doesn't. You will haffta make an adapter to fit the gearbox and grease gun. This is sumptin' enny clever shadetree mechanic can do.
As fer yer TO-20. I believe its the same tranny splash-lube design of the 9N/2N as Harry "borrowed" the drawings from Henry. NO GREASE for TO-20, just check yer hydro-tranny oil level dipstick behind yer right heel (5-gals). Simple, eh? .......Dell
