Well i put a new coil on it, new points, and checked some of the wiring, found a couple of wires that had melted together, fixed them, started it and measured the volts on one side of coil, almost fifteen, measured the other side, goes from 7 to 11 volts, dose'nt have a resistor wire, it has a one of them ceramic resistors on the firewall, pulled it off and looked at it, dosent look bad, the fuse spring deal is still in one piece. How do you know if it is bad, and what is the correct way to check the volts going to the points, just check the side of the coil that goes to the distributor? Thanks for any and all advice. Bob
