You folks have wagons like these?
Anonymous-0
Thinking about buying this to replace the 2 axle wagon I have. Floorspace is the same as the 2 axle one and this one will pick up loose hay/grass and unload it. Also can put the frame up for the top (can't see it in the pics) and cover it with a tarp to store about 150 bales... Price is right at 25 bucks, just gotta make sure nothing is rusted thru.....
You"ve got a wagon with storage capabilities, self
loading, AND self unloading and you"re worried
about rust?
I"d just marry it and worry about it leaving me....
Thanx for sharing.
Kinda had one like it, without knowing it, years ago. Was feeding cattle in the field, by myself, before and after work. Had been tying off the steering wheel on the tractor, put it in low, jump off tractor and on to trailer, and throw it off. Kind of a hassle- so I took the beaters out of an old manure spreader, left the bottom chain hooked up. Line up the bales, take off the strings, put 'er in gear, and off we go. Dropped the hay off the back, one sheaf at a time.
I like that wagon- especially for 25 bucks!
(reply to post at 10:32:09 10/30/11)
They are around all over at different conditions and prices. This one is about 10 miles from the house. Weighing the convenience and price against one in much better shape but 300 bucks and a hundred or so miles away. Can just drive the tractor to get this one.
(quoted from post at 10:53:08 10/30/11) 25 bucks and you haven't bought it yet??Are you crazy!
If it sounds too good........... Typo... Just called about it and the price is 250....... Still OK tho, just gotta look at it (little harder at that price tho)...........
Dave , If you go to look at it you will be back on here in a few days saying the guy is a knothead and was 10 min. late to show it to you and did not have enough air in the tires and on top of all of that you took the day off work and he should give you $25 to take it !!
