IH combine head
Anonymous-0
hello, whats the difference between a 844 head and a 944 head? looking to put it on a 715 combine. will this be a good set-up? we have always put all of are corn in silage up until last year. this year were making some changes and will have more corn in. we picked up the 715 and we now need a head.any info. will be appreicated. thanks
Several parts on the 944 were changed from steel to alumium to make the 944 lighter than the 844.
I have had both and if both heads were the same condition I would buy either one.
No major difference between the two so go by condition.
Gary
The 800 series head as mentioned was quite a bit heavier. It has bushings rather than bearings at the lower end of the stalk rolls. Output shaft on the gear boxes uses pins that habitually wallow out the shaft hole. These double roll pins then easily break or work/fall out. Many convert to bolts which work pretty good even if the shafts are worn, although they give up some shock protection. The 900 is splined and doesn't have this problem. Nearly all 1000 series parts will fit the 900 which isn't true for the 800. So if you want the 1000 updates they are much easier/cheaper to install on the 900. The 800 is a good head and the bushings will last longer than the 900 needle bearings if you don't grease often enough. The 900 had aluminum rolls which can fatigue. Those with any amount of hours have already broken and likely replaced with the 1000 series malleable iron. The early 900 aluminum gear boxes had a tendency to leak and most if not all were updated to fix this problem.
