WoodsL306 from AC Model C to JD Model A or q...
Does anyone know if a Woods L306 finish mower bolted to a AC Model C will bolt to a JD Model "A" or "50"? If not, would the necessary parts be readily available?
(quoted from post at 12:20:05 03/16/12) Does anyone know if a Woods L306 finish mower bolted to a AC Model C will bolt to a JD Model "A" or "50"? If not, would the necessary parts be readily available?
No doubt it will require different mounting brackets, and probably a longer belt. A Woods dealer should be able to fix you up. I've got the L306 mounted under a Farmall H.
The parts can be obtained new from a Woods dealer, but it will not be cheap.
That mower definitely will NOT bolt up directly without different brackets and/or modifications.
You go to your Woods Dealer as you need some brackets for your tractor you will be better off putting it on the 50 as the A would be a beast trying to mow with.
