13.6 x 28 Tire Chain Dimension
Billy NY
Anyone have a rough idea of the actual dimensions of tire chains for a 13.6 x 28 tractor tire? (double ring type)
I can not tell you but I can tell you how to find out as long as you have the tire on hand. First this works best on concrete. Mark a line in the tire at the bottom and a line on the cement. Then roll the tire one as in 360 full turn then measure that distance and you have the length as for how wide measure across the tread going about half way down the side wall and you have how wide they need to be. That will put you right in the ball park. My self I make my own tire chains by picking up use truck chains from truck stops etc.
I looked back on this forum I posted this question before and I think you mentioned that then. Always reading the adds, more than anyone I know I think, (its addicting cause I find great deals LOL)I found a nice set of double ring chains but they are 11 rings wide 29" x 12' or so, might be a tad wide, length would be no trouble with the tool, then again..... could shorten those too, let em hang off, or cut.
All the tire chains I have for my tractor where made from scrap iron chains I have picked up over the years. Truck or county grader chains then cut or added as need to make them fit. Been using one set now for well over 20 year that I made that way
I have a set of double ring chains that fit the 14.9x28 tires on my MF 65 very nicely. They have 7 pairs of rings in the cross chains, 14 cross chains and 62 links in the side chains. You would probably want 1 size smaller for a 13.6x28.
I just went out and measured the chains on my Allis WD-45.
It has 13 X 28 Tires.
Each cross link has 11 double rings (2-1/4") plus 2 oval links plus the two clevises that attach to the side links.
There are a total of 13 cross links spaced at every 5th link of the side chains.
Hope this helps.
