Bobcat S-175
Fritz Maurer
Traction lock unlocks when it wants to. Trouble code 15-03 (solenoid error OFF). Checked fuse/breaker panel for corrosion per dealer instructions. None. Removed solenoid to check for broken wires or other damage. Reinstall unit, ran another 1/2 day and started acting up again, this time locked up during operation. Found top blown off traction lock solenoid. Install new solenoid and fuse, runs fine another day and a half and now won't unlock, back to original trouble code. Any ideas? Can I use a test light without smoking the computer? Thanks, Fritz
Is the traction lock light going off? Could be a loose wire. Dealer should have a program called BATS. They can look up that code and it will give them a list of possable issues. Check when the alarm goes off and see if there is another code. Usually if there is an electrical issue there will be multiple codes. You may have to have them hook it to there computer.
