I"ve got a Ford 2110 tractor and having some trouble. When the tractor is cold all gears shift fine and tractor runs as it should. When it gets warmed up, the tractor speed gets slower and have to gear the tractor down to keep it moving. It finally gets to a point that it will only move in first gear because it won"t pull in any other gear. All gears still shift fine. Its almost like the clutch is still pressed in when it does this. I also noticed that if I drop the rpms when the tractor is moving, that it actually helps the tractor pull a little bit. I"m thinking the clutch is worn out. What is everyones thoughts? I"ve got the clutch adjusted all the way out so I can"t make anymore adjustments there.
Thanks.
Thanks.
