Lucas hyd oil treatment
rrlund
Anybody ever used Lucas Hydraulic Oil Booster & Stop Leak?
I've got a seal that's gonna be a pain in the backside to replace that's dripping. It's not blown and spewing oil out,but just drips. I've used other Lucas products and had good luck,just never tired the hydraulic stuff before.
Lucas hyd treat
It works pretty good. I use it in my semi hyd tank. As long as it isn't a pouring leak. It also gives a little boost in psi [about 100 psi at most]. I use their hub oil and engine oil treatment also,engine oil saved me a 15000$ engine rebuild on the big truck. Trucker
I have used it several times. It is sure worth a shot.Cleaned up the leak on a couple machines. Made one worse as it raised the system pressure. Needed fixing anyway. but got us thru a busy stretch.
I have seen it dry up or slow to the point of little concern, the lift cyls on a fleet of dump trucks, in a couple weeks. i don't know the %
