need a measurement or two off a JD 1450 tractor
Our JD 1450 tractor is missing the pin that holds the drawbar in. Can anyone send me some specs for this pin, a picture, or some measurements? This pin is NLA and I think we"re going to have to make one (I think it"s a bit special with a bolt on flange that holds it in).
Thanks for any help you can provide!
Tom
Part # is CH17382 and if you GOOGLE that you will find a number of sources. Otherwise, it shouldn't be too tough to measure the hole diameter and the distance across the plates.
<img src = "http://jdpc.deere.com/pimages/RWP4/RWP4515________UN01JAN94.gif">
(quoted from post at 03:26:54 02/25/13) Part # is CH17382 and if you GOOGLE that you will find a number of sources. Otherwise, it shouldn't be too tough to measure the hole diameter and the distance across the plates.
&lt;img src = "http://jdpc.deere.com/pimages/RWP4/RWP4515________UN01JAN94.gif"&gt;
Bob, I tried about four sources off of google and no one has it, new or used. Any further suggestions about some really good sources for used JD tractor parts?
Thx,
Tom
