751 delco light plant
wally_mi
need your help please, i have the delco light nplant running but, can't get the air and gas regulated. i think there is parts missing on the carb. would like pics, books or any help you can give trying to have it running for the clio antique engine ande tractor show in sept. thanks a bunch. wally
Are you sure that the fuel you are using is correct? Distillate or tractor fuel may be what what was used back when. These may be difficult to replicate now. Maybe someone on here knows.
With it running spray some WD40 around the intake and carb mounting areas and see if the engine rpm changes, if so you have a vacuum leak. This is what it sounds like to me. But with out seeing it, this is just a guess.
it has new rings,valves,gaskets, cleaned the carb, had the fuel pump rebuilt so could run modern fuel made a stader plate and its timed right. with new points and condcer. thanks wally
