3 axle trailer and a JD 410 hoe 4x4 with ext. hoe
lenray
Will this trailer be enough to haul this tractor 120 miles. 8 bolt heavy duty rims. Ford V-10 Super Duty.
I know a double axle with 8 tires would be better, but the triple axle is what I have with 6 tires.
Thank you
If your axles are 7k or better, and they should be, you are ok. The trailer would have a 21k rating and the loader has an operating weight of about 15,900 according to JD specs, so you are good to go.
I have a triple axle trailer with G rated tires and have at least 2 tire failures a year . don't know the answer but my next trailer will be a tandem dually.
I have a 410 G that I have hauled behind a C8000 dump truck on a heavy equipment trailer with tandem duals and air brakes. No way would I consider hauling our 410 with a pickup and trailer you describe. In fact we got rid of our outfit and now use a 46,000# roll back truck which is a lot safer. Hire someone with proper equipment to move it. Might not only save your life but some innocent person(s) traveling the same road too.
If you have an F450 super duty you have enough GVTW to handle the load. Anything less you do not have enough truck, this is taken from the Ford spec book.
i have a three axle trailer that is rated at nine ton but the POS has 8-14.5 tires on it and if they are just a little out of line it eats them like candy and also you must have brakes and a brake away on the trailer. if your trailer is in tip top shape it should be fine for the load but seeing you have asked you most have some doubt about it. also it needs a DOT inspection sticker. Good luck
