MH44 EFI Manifold changes
David G
I have the manifold drilled for the changes. The bottom hole is for the idle air control, middle for fuel injector and top for vacuum port to MAP sensor.
I will have everything done except fixing fuel tank leak this week. I am firing it up with carb and dist to check out all sensors, will then convert ignition then fuel.
The tank has a leak where one of the bolts goes in, I am going to strap it to wheel on other tractor, clean and seal it.
