Because of a severe leak in the bucket cylinder on my Farmhand F10, I plan to convert it to double-acting cylinders on the bucket. The reinforced welding areas have made it impossible to get the original cylinder out without cutting the square main tubing. I plan to run the PTO pump through a open center dual control valve.
Will I be able to use the double-acting cylinders on the bucket, and continue the single acting cylinders on the loader lift by running it through the open center valve?, or do they all need to be double acting cylinders?
