Anonymous-0
I am in the process of converting a 1953 Farmall Cub from 6 volt to 12 volt electrical system using a 10SI 110 Amp one wire Alternator using 16 or 18 gauge wire with a 1 amp/50 volt diode in line. I know the Alternator wiring is suppose to be somewhat easier when using an Alternator with one wire or so stated in the 5/23/13 article reference Recommendation for 12 Volt Conversions referencing an Article Copyright 1999 Genesee Products. That article explained somewhat how a two and three wire Alternator wires out, but, although briefly mentioning a one wire Alternator, never indicated the completion of the one wire Alternator's wiring. My question is, does that single Alternator wire run from the Alternator directly to the starter stud or does it run to the ignition switch?
