Josh in Pa
I have a 20 hp b&s vanguard on my mower. Lost power, missed real bad and blew black smoke. Also backfired through the carb some. Pulling one plug wire makes no difference, but the other kills it instantly. Cylinder that is not firing has 150 lbs compression, both valves move. Tried two coils and disconnected the kill wire from both coils. No luck. Started it up, it seems like it is getting oil inside the air cleaner, and with a valve cover off to check that valves were opening, seems like a lot of pressure in the crankcase. Any ideas where to go next?
Josh
Josh
