Another question about gas tanks.
HenryO
Now assuming my gas tank is clean, can Ospho be used to coat the inside without harming the so called gasoline. In other words, if I put ospho in the tank to seal the rust will it affect or be affected by gasoline?? Thanks Ospho is a mild form of Oxalic acid that is used as a rust reformer.
It has been many years since the last chemistry course, but I don't think it would cause any problems with gasoline. The chemical reaction with rust results in two stable coumpunds. We used a lot of Ospho offshore on rust before we painted it. Didn't seem to react with the new paint or the old paint.
If I have a gas tank that is extra rusty inside I try to get as much scaley rust out then sloush Ospho all around and let it air dry for a few days then I use Red-Cote tank sealer
I have had good success doing it this way.
I have used Ospho for several years and its good stuff.
[quo
te="Harvey2"](reply to post at 03:43:14 07/30/13) [/quote]
Ospho is mostly phosphoric acid. It converts iron oxide to iron phosphate. It is a good primer but it is not a finish coat. Use a tank sealer.
