Help with leak
Anonymous-0
Where can I find a gasket and how do I identify which one I need? I recently notice my tractor leaks right below the shifter, at the very bottom of the tractor where the transmission meets up. Is this something to worry about? (Ford super dextra)
Sounds to me like you need a seal not a gasket. The leak is most likely from either the rear main seal of the motor or the input seal of the transmission. Whichever is leaking, it runs to the low point then seeps out. Most tractors have a hole in the bottom of the bell housing to allow the oil to drip out. Either one requires a split to replace. It is customary to replace all bearings and seals that are there while it is apart.
