Location of grease fittings on Farmall M
chappie
Can someone please tell me if there is a place online to download a picture chart that shows the location of all the grease fittings on a Farmall M or Super M. I think I found most of them, but I may have missed a few.
Thanks
The most over looked one is in the flywheel. You have to turn the engine over slowly by hand. Till you can feel it in the edge of the flywheel. It greases the pilot bearing. There is also through out bearing. On the left side through the hole. On the left side there is a little cover you twist with your fingers. The rest are pretty visible.
Cat guy is exactly right; I even knew about the pilot bearing, but just forgot it over the years. Took it apart and it was real dry and gritty in there.
There is a very good picture and description in the operators/owners manual. It even tells you how often to grease each zerk, and how much to put in.
