1960 Case 910-B LP
RS16017
I"ve got a line on a Case 910-B LP gas tractor in good shape. Anybody know anything about these. Tractor Data says there were only 1000 ever built. Any weak areas?
1959 was the last year for the 910-B, that is for number the 1960 was a 940 LP. I have the 910-B now and did have the 1960 940LP. My 910-B needs a overhaul but in it"s day was a good solid tractor.
The steering was a week point, at least it was on the 930's that came after it. Leaking steering cylinder and a pump with a very limited reservoir, and steering play. With such a short wheel base a little play in the steering is troublesome at speed. Also, if you can, take it through the gears. Second gear is the heart of the tranny and you could find it to be worn out and noisy.
