Farmal 460 puller
you need more air -- take the oil out of the oil bath and bore out the ventury in the carb to at least the size of your thumb--- more air more power -- its that simple --
Good luck with that , years back we managed to get mine down to just a shade under 5200 . First off went the fast hitch , next was the PTO . Then we used a draw bar off a H for a hitch . Now maybe and again i will say maybe If you ditch the cast centers for a set of nine bolt hubs and tin wheels and a scrap out all the hyd."s and remove ever inspection cover and replace with aluim. scrap the seat assembly and come up with some extra light set up that won"t break and cause you to fall off the tractor . Then ya MIGHT make it .
