Irrigation Filters Plugged with Lime
FBH44
Finally discovered my very fine-mesh irrigation filters were plugged with invisible very fine deposits of lime. Have been losing pressure for a long time now. Soaked them in Lime-Away, which worked, but CLR really works. Have more pressure out in the field than I ever have had.
Anybody else have good / better solutions to handle lime??
The solubility of lime in water decreases as the temperature of the water increases. This is the reason lime collects in your water heater.
This would suggest that you would want to filter the water cold as it comes from the well rather than after a long run of pipe that could see warming from the sun. Also, you may want to drain the system/filters (may not be practical) rather than allow water to sit and warm to outside temperature. I would not think this alone would stop the fouling however, it may reduce the need for cleaning.
Just a thought.
