This is a wrecked machine that I got at an auction. IF I can get it to run, I will put the engine in an old 72 Chapporral. I attached a battery and the tail light is on. There is not a key in the switch. Is the switch in the ON position?
The back of the switch has power to a red wire and also a brown wire. I believe that the red is power in to the switch and the brown must be power to the lights. When I put a jumper wire from either of those two terminals, to the red wire that has a white stripe, the starter engages, but the plugs do NOT fire. When I touched power to one of the remaining wires, I blew a fuse. I replaced the fuse.
The coil has two wires attached to it, and of course the two plug wires. Can I attach a jumper wire to the coil from the battery and then look for the plugs to fire when I engage the starter?
I want to get the electrical in working order before I put any gas in it.
Thank you
Steve
Thank you
Steve
