Slow Hydralics on front end loader
Gman2370
New User
I have a 2007 John Deere 990. It has a front end loader on it which works great except that it is extremely slow. Does anyone have an idea how I can fix this?
Unless someone has replaced some of the hydraulic lines with smaller ones that are holding it back it may be just the way it is. The smaller tractors have small pumps in them and they only have so much volume. The larger the cylinder the slower they get. In the case of a loader you are filling two to four at a time depending on how your control works and how many valves you can use at a time. As far as I know there are not allot of options for installing larger internal pumps. If it was external pump then you could maybe install a larger pump capable of more volume.
Greg
Are you sure there isent a way to turn
Up the speed faster? Both of my fords have a dial to make the hydrulics faster or slower.
