briggs engine valve seat
55 50 Ron
photo is of the intake valve seat on an "L" head Briggs on a lawn mower. Is this economical to fix if I do it myself?
Briggs wants 22.95 for the repair manual. I am thinking of tearing into it without the repair manual.
Have any of you repaired this type of problem on one of these engines and what do you recommend?
Thanks Ron
Seen that before and put the seat back in place then used a punch to peen it in and held for I do not know how long since I sold that mower years ago
I learned that from a guy in town who just this past winter closed down his lawn mower shop. I know his shop has or had been here for 34 years since it was here back in 1980 when I moved here
Hi, idid that on a bearing on wiper motor on chev pu.
the noise was quite annoying. The center punching
all around bearing tightened in place good. I would
go 1 side then the other all around. I punched about 3/16
in apart. Sould work fine. Ed will
Had one of our kart racing engines do that one night. Popped the head off, pushed the seat back in to the bore, staked it in with a hammer and screwdriver, and sent the kid out for the feature race.
We put a lot of races on that engine afterwards but the seat never came loose again.
That was a very common problem on the L head Briggs. I used loctite and the punch like the others have already mentioned.
You will want to check your cooling fins. Make sure they are not full or grass, dirt, or grease. Running too hot makes the aluminum expand too much and lets the seat fall out.
I'm with the rest here. Put it back in the bore and peen it in there. I used to work on allot of old Corvair's and the 140 engine was famous for dropping seats. Fixed them the same way. Lasted as long as the rest of the engine.
Greg
I honestly had to look twice to make sure that wasn't a picture of mine that I took about six months ago! Mine is in a 20 horse flat head twin. I put it back in and peened all the way around it with a center punch and hammer. I may have gone overkill, but I staked it about every hour on the clock (one at 12, one at 1, one at 2, etc) so I had at least 12 total. That thing is never coming loose.
I use it twice a week for about 5 hours at full tilt. She runs like a champ. The worst part was getting the valves out to adjust them. I made my own spring compressor from a tie rod fork with a washer welded on it (with a notch cut out).
