scrambulldacres
New User
I have an H that has a dead spot on the starter, I can hand crank it over and then can hit the starter and it will start. Had it running and then it died...battery was weak so we pull started it...it ran again for a few minutes and then died again. When I tried starting again it fired but then stopped. I can't turn it over by hand anymore and when I tried to pull start it won't turn over that way either. I pulled each spark plug and found them to be dry....the last thing I checked was the coolant and it was very low which was not how I had left it when I had it running last...opened the petcocks on the oil pan and the oil came out black so don't think the coolant went into the pan. Would it have locked up that fast or is it just vapor locked somehow? Any thoughts would be appreciated
