i have a john deere 850 with a add on 3point backhoe, the pump the last owner installed on the pto shaft wasnt up to my expectations, and according to northern tool help wasn't designed to work with that application, i replaced it with a much larger prince pump these pumps are shown in the catalog sitting upright that is with the larger part of the pump up, im having clearance issues with my upper link mount that way, does anyone know for sure, can i run it with the large part facing down? i can turn the pump around and the rotation will be correct, but im not sure if the pump is designed to work that way , the upper link is critical as it also mounts the top of the backhoe to the tractor
