Ferguson T35
Have a 1964 T35. Just replaced clutch and pump in gear box. This little machine is a beast. Have a 2 bottom plow, front end loader, and 6' disc, bush hog and back blade. Wife and I have 12 acres and giving pumpkins and watermelons a go God willing in the spring. Any thoughts?[/i][/b]
So what's your question? that 'little' tractor should be more than enough. You may need to pick up a drag harrow, cultivavor and
planter.Maybe couple of other pieces.At minimum,remove the bucket when you are 'farming'. Better still,if you can,remove the
whole loader. Lots easier to 'farm' without dragging that heavy loader around.Giveing back to God is awsome!Go for it!
(reply to post at 16:03:26 11/15/15)
Steve, Readjust your points and you should be good to go. Coil is hot because the points are closed, you may want to install a new set of points at this time and don't forget to lube the point cam(where they rub on the distributer). Chuck
(quoted from post at 13:23:53 11/15/15) So what's your question? that 'little' tractor should be more than enough. You may need to pick up a drag harrow, cultivavor and
Not really a question. Just excited to get going. Been gardening a lot of years and now going to go at it on a larger scale. Removing the loader bucket is easier than removing the whole loader. Just trying to get and stay in touch with folks that have older equipment.
