I'll ask this question here since lots of you guys have engine experience and gas with ethanol. All my small engines have problems running correctly most likely due to running gas with ethanol. They run like some jets are plugged and need to use choke all the time. What's the fix to an engine already with a problem. I've used a lot of carb cleaner with some results but I'm thinking its going to take a carb kit to fix the problem. I'm sure lots of you have experienced the same problem - how did you fix it. They have all had gas/ethanol from day one so its not because the gas mixture is cleaning out junk. Had that problem on my 184 Cub.
