Instrument panel Fordson Super Dexta
sladetb
New User
I have a Fordson Super Dexta with some missing instrument panel pieces. The only gauges I have are RPM and temperature. There are several holes on the lower panel that are missing some parts. Not sure what should be there ?
Oil gauge... iirc... then there were a green and red idiot lights again iirc.... one was the high beam, and the other was the generator iirc... it was 35 years ago since I had that tractor.
Thanks for the feedback. Is there also supposed to be a pre-heat switch or light switch ? Working on restoration as close to original as possible.
No oil gauge. One light for oil, one for generator. I'll try to get a pic of mine later although I cant guarantee its all correct.
To the left of the rev counter ..... Top Left ... Stop control cable. Bottom Left ... Light/ignition switch (Dexta) ... Light switch only ... Super Dexta, (Super Dexta has ignition switch on the side of the dash panel above the clutch pedal).
To the right of rev counter ..... Top right ... Horn button, Bottom right ... Heater button for manifold heater.
