hunterjoe37
New User
Hello all, Glad to finally get signed on, have always enjoyed reading the vast knowledge base, and have always found my answers until now.
I have a MF35 Utility tractor with the Z134 Continental Engine. I am in the process of trying to convert this tractor from a 6v positive ground to a 12v negative ground and convert it on over to electronic ignition. I am also wanting to go ahead and replace the distributor, due to slack and wear on the gear.
Now here is the question. The number on the current distributor in the tractor 1112589 9A21 delco. All the research that I have done, shows this distributor fitting a MF65 tractor with a G176 engine, which is a totally different size. I would like to order the proper distributor for this size motor, especially if there is a significant difference. There are so many different part numbers that go along with distributors for these motors, I'm not sure which one I should buy. If they make one that already has the electronic ignition module installed, instead of points,that would be even better.
The serial number on the tractor is UGM655000466
The serial number on the motor is 733078
Any info or expertise with this will be greatly appreciated.
Thanks,
Joe
Thanks,
Joe
