Hi / Low Lever on Ferguson TO20
My TO20 has a lever on the left side, above the clutch pedal. I have looked but can not find it on any other TO20 pictures online. I was told it is a Hi/Low lever. Anyone else have one? If so, can you share a picture? Thanks.
Picture of mine below.
The term Hi/low is not really correct. Likely you have a Sherman 2 speed and one is over drive and the other gear is the standard gear that would be on that tractor if the Sherman was not there. There are a number of Sherman's to be had. Some where the over drive type others where an under drive and also there was the combo which gave you over under and standard gears. To check to see if your lucky and have the combo shift it to neutral then pull out side ways on the shiftier. If it pops out about a 1/2 inch or so then pull up on it. If it goes up then you have a combo which gives you 3 gears and that would make your tractor have 12 forward speeds
I owned a 841S for a number of years before I found out it had 4 other gear to it because it has a Sherman Combo in it. The S behind the 841 tell a person it has a factory installed Sherman. Ford by the way
Check out [b:3cc4f1f8a2]John Smith's[/b:3cc4f1f8a2] excellent site for details on the Shermans et al.
Yes, its mainly a Ford site, but you may find your trans there.
