Electrical Adapter Available???
Dumb, I know, but I'm buying a new tractor. It has an outlet on the back with round pins. That looks similar to the "flat" outlet of my pickup, trailers, etc. Is there an adapter from the round pins to the flat? I'd like to be able to hook a trailer behind so that the lights work. Thanks, kelly
Just make a cheater cord, with the front matching the tractor plug, the rear matching the trailer plug. VOM will tell you which terminals are powered in various positions.
The plug on your tractor is the same thing semi's use, and I beleive it is wired the same also. Has been the standard on farm equipment for 30 years.
As others have stated there are adapter available or if you can't find what you want just make one yourself.
The attached link will take you from your tractor to a 4 pin flat.
jt
Untitled URL Link
The plug on the back of your tractor is the same style as a semi trailer plug. It is NOT wired the same. I just made an adaptor cord like JMS/,MN said to do. Semi male plug on one end and female trailer plug on the back end. I then wire the cord to make the lights/turn signals/etc. work on the trailer half.
I'm not sure just which plugs or receptacles you're talking about, sorry. The big semi truck and trailer plugs and receptacles have round pins indeed. Often pickup trucks and small trailers use the light duty flat 4 (or the newer 5) receptacles and plugs, while newer pickup trucks and many RV's use the 7 blade (6 flat + round center) with round outer shell plugs and receptacles.
They make all sorts of adapters for the small flat 4 or 5 pin to the 6 pin horse trailer plugs or 7 pin RV plugs etc but fewer adapters (I have a couple) to go from semi truck to RV etc. Check with Amazon or E Bay or Adventure RV or Tractor Supply or Rural King etc.
John T
