this is my first post but I have learned a lot by reading this forum thanks guys.
I have a 52 To30. When I got this tractor it was absolutely shot. So I took it down and cleaned and inspected it. Put it back together and found that my intake manifold is now blowing air rather than having a vacuum. From what I have read, it is most likely a timing issue. I did not pull the crank nor the cam shaft so that timing should be good. I'm wondering if my ignition timing is causing it? I believe I have it right. I timed from tdc. Just wondering if there is anything else it could be.
Thanks
Thanks
