utting = cutting.(quoted from post at 23:01:13 03/03/17) Get one that the deck extends about 3 or so inches beyond the rear wheels. It makes [u:dcfd825748]dutting[/u:dcfd825748] around trees, etc. easier than if wheels are at same place as outer edge of deck.
(quoted from post at 20:14:46 03/03/17) Looking to buy a zero turn mower. About a 40-48 inch cut. Have a lot of trees to mow around. What is a good brand to buy and what kind should I avoid. This will be parked in the shed with my tractors so that makes it tractor related.
(quoted from post at 14:04:40 03/04/17) Country Clipper is the best on the market. And has joy stick controls. This allows you to enjoy a beverage while you mow. Thats a big plus for me.
(quoted from post at 14:36:08 03/04/17) If you have small trees(2" dia.) you do not want a zero turn. If you have large trees you do not need a zero turn. Think about it with small trees. The privet point for turning is the back wheel. So set the back wheel next to small tree and go around it and you leave a 8" circle of uncut grass. What you have to do instead is put the deck side next to it and kind of walk your way around it back and forth. I got an all-wheel-steer. That's the cats meow for going around small trees. Also you cannot cut steep side hills and ditches with zero-turn. They keep falling down hill. Don' know if that's an application for you or not but it was for me.
