Narrow grain drill
cool hand
Location
SE IN
I remember very early in my life, probably around 1940, my Dad using a very narrow, maybe 3-ft. grain drill to sow wheat in corn before it was harvested. At that time corn rows were spaced 42 inches. It was pulled by one horse. I don't know if it was his or if he borrowed it, but I don't remember it being used after that. Anyone remember those?
My neighbor has an original fully functional Van Brunt just like you described. It has 5 disc openers and a pair of handles for walking behind. Holds about a bushel of wheat and you can adjust the opener spacing. I used it behind a four wheeler to seed my first acre of wheat back when I was 8.
I have seen them but could you just imagine walking thru green corn with one. It would be enough to cut you and the horse to pieces. Tom
McCormick made a 7 run drill. It has hoe furrow openers. The pole is offset to the left so the right horse does not walk on planted ground because it is so narrow.
Jim
Several companies made relatively narrow grain drills used in some areas in a one pass operation using the tractor to pull a moldboard or disk plow, a secondary tillage tool of some sort and then the drill of approximately the same width as the freshly tilled ground in a combination. I've personally never seen it done but seen several pictures of it being done.
Did it look like This
