Hey has anyone ever used a xenon timing light on a tractor setup with a 6 volt system with positive ground?
Reading the instructions it says to power the light of an auxiliary 12 volt battery ... Got that ok but then it also says to run minimum 18ga wire from the negative of the auxiliary battery to the ground on the engine.... But ground in this tractor is 6volt positive... Does not seem right to connect the negative of a 12 volt battery to something that the positive of a 6 volt battery is attached to?
Any help appreciated
Thanks
Thanks
