(quoted from post at 02:04:45 08/09/17) Please explain how a station does not put ethanol in their 93 octane gasoline.
(quoted from post at 20:56:03 08/08/17) Local farm equipment dealer says to use 100 octane leaded airplane fuel in antique tractors that sit a lot. They fire up much better.
Any opinions on this? Apparently the shelf life is much much longer compared to auto fuel.
(quoted from post at 22:42:27 08/08/17) they might fire up better, but you will burn the pistons out if they are worked. too hot.
(quoted from post at 08:08:55 08/09/17) You're exactly right and apparently few people understand what high octane fuel is all about,it'll cause a normal compression engine to carbon up then fuel will preignite from the built up carbon. As you stated he higher the octane the harder it is to get to burn.Millions of dollars are wasted on 'premium' gas every year by US consumers.
(quoted from post at 06:01:03 08/09/17) Actually airplane fuel has the same shelf life as any other fuel. Save yourself some time and money and add stabile to ANY fuel that's going to sit for a while. If it sits a long time I'd ad some Seafoam too.
(quoted from post at 11:39:38 08/09/17) 100LL is much higher quality fuel, and much more care is taken to ensure its stability, because having an engine quit on an airplane is significantly more inconvenient than having an engine quit on a car.
For those who need a clearer picture painted, when an engine quits on an airplane, it falls out of the sky and someone usually dies.
They could make automotive fuel just as good, but nobody would pay $6/gallon, or whatever they're charging at the airport now.
Besides, can't buy 100LL around here. The airports around here will blow you in to Homeland Security as a terrorist for even asking.
(quoted from post at 15:30:08 08/09/17) On another note, I want to warn about the use of avgas in farm vehicles on a regular basis. 100LL contains tetra-ethyl lead in small quantities. Since exhaust on tractors is often primitive, and often blows from the stack directly in front of the operator, this raises a situation where the lead constituents from burning in the engine would be ingested in higher than normal quantity.
Lead research has a long history, going all the way back to the English using lead to form hats. This is where the expression 'mad as a hatter' comes from. They are not mad, as in angry, they are mad as in insane. Even very small amounts of lead in the human body cause irreparable harm. Lead is also not easily removed from the body once it's inside, and the effects are long term as well.
Of course, we all know that when a home is sold, a lead paint warning form must be filled out. Working behind a tractor, typically running rich, with leaded gas is a recipe for serious health issues that can't be reversed.
I would say that using small amounts of it, on a rare basis for stability would be ok, but try not to breath the exhaust fumes if you have a front mounted exhaust stack.
It may surprise you to know that 80% of the aviation engines have about the same compression ratio as cars and tractors all of the engines designed to burn 87 OCT av gas were low compression the comp ration of a Lycoming O-360 180 hp consider high compression is 8.5 to 1(quoted from post at 08:30:24 08/09/17) Thanks Jim! Why would anyone pay extra for high-octane fuel and put it in a very low compression engine!!! It seems more common all the time that people would rather believe myths and rumors than facts! For our Farmall C I buy the 87 octane with ethanol and then add a little diesel to lower the octane and reduce gas tank corrosion, and it starts and runs great, even after sitting 6 months with last years fuel!
