(quoted from post at 14:17:44 10/28/17) I knew three guys that tried grain trailers. They all ruined there pickup transmissions. I don't recommend one.
(quoted from post at 14:59:28 10/28/17) Rockyridgefarm, I agree. I don't see as hauling grain would be any different than hauling a loaded flatdeck around, or hauling gravel, or dirt, or anything else in a dump trailer behind a pickup. All boils down to how heavy were the loads and how rammy was the operator.
To the original poster, any dump trailer would serve well as a grain trailer. Build extensions if necessary, and build or buy a grain endgate. I personally like the Precision brand, built in Manitoba. The Precision flatdeck goosenecks that I've had have served me exceptionally well. Pricey, and heavy, but well worth it for the quality.
(quoted from post at 05:44:08 10/29/17)(quoted from post at 14:59:28 10/28/17) Rockyridgefarm, I agree. I don't see as hauling grain would be any different than hauling a loaded flatdeck around, or hauling gravel, or dirt, or anything else in a dump trailer behind a pickup. All boils down to how heavy were the loads and how rammy was the operator.
The real difference here is that a pickup with an auto trans has to take whatever you give it when you press the pedal. Conversely a "real" truck with a real transmissions has low gears for those tough starts. The owners manual will tell you to select a low enough gear that you don't need to give it ANY throttle to get it rolling.
(quoted from post at 16:43:42 10/28/17)(quoted from post at 14:17:44 10/28/17) I knew three guys that tried grain trailers. They all ruined there pickup transmissions. I don't recommend one.
Tractorguy,
How does a grain trailer wreck a transmission? I would think a load of grain would be more stable than a load of equipment and be better to pull. Did they badly overload their trucks? Were they older automatic trannys? I'd like to know because I too would like a grain trailer.
