Eboram
New User
Hello all,
I just purchased a long 2460dtc that set for a yeat put an injector pump on it re timed it and now number 1 cylinder is not firing changed injector still not firing good compression could this be a stuck intake valve or a bent Rocker arm? Any help is appreciated.
Not a stuck valve if it has compression.
But do check the valve train, could be a bent ex push rod, broken rocker.
Did you bleed the line? Getting fuel to the injector?
We have a 5 cylinder Kubota that had a dead cylinder after pump overhaul. Had a bent connecting rod on number 5. Piston liked about 1/16" coming to top of block, that was enough so that it would not fire. Was that was when we bought it, running on about two cylinders because of a worn injection pump. Not sure what bent the rod-maybe coolant got on top of piston. Do not know history of tractor, but we have put over 1,200 hours on it since then with no problems.
Garry
Can anyone tell me this my injector pump has an a b c d e f G h which one is the timing mark how do I time this pump correctly feel free to call me 3046723944
Found the problem blowed head gasket between one and two cylinder. Does anyone know the torque specs for the head and sequence?
