Bobcat 763H
Tony in SD
Im having trouble with the interlock system the seat light is intermittent depending on how move in the seat, the brake light is off the valve light is off, and the safety bar light is on.
Does anyone have a wiring diagram or any ideas?
Take the seat out and clean under it. Don't asked how I know to do this. LOL If there is not junk under the seat then I would bet the seat switch itself is going bad. We have two Bobcats and I keep a seat switch on hand. The fact it changes when you move around in the seat is the clue I am going off of.
I think I have multiple intermittent issues. But that is an easy start.
Some time ago the garage remote in the bobcat disappeared. At the same time I also had issues with the seat interlock. As I pressed hard enough on the seat to get the bobcat moving the garage door started to close as I was backing in. Turned out the opener was the obstruction under the seat.
