W-30.....HELP
banjoman09
Have posted twice- are you guys mad at me or what..... Trying to find a pic or two from a W-30 Owners Manual to show me the correct way to install the ; oil pan, rope wickers, and oil pads on top the rocker shaft assembly. Thanks.
Advice. Joking or not, asking if we are mad will not get you very far. Someone would need to find their copy of the manual and photo it and post it. Maybe if they had it out already it would work easily. F-30s are not that common. This site sells them, and is reasonable. Not a flame, just advice. Jim
Untitled URL Link
You might have better luck asking over on the Farmall IHC forum. Also a lot of people who have what you need do not have the knowledge or hardware needed to post a page from a manual on here, me being one of them.
Seems like the 1930's tractors don't get as much response on here as the letter series, especially the standard ones. Don't know why - maybe just a lot more letter series owners.
I just put a couple pics on your post on the Formal forum , not sure if they are what you want but all I have found so far.
as i stated before... put the puzzle together, nothing hard. the flat felts fit in the oil trays and the small felts go over the valve stems. i will send u a picture . dont really see why your having trouble with that.
Because I dont know how it goes in there...thats why- pan first? Pads first? My pads have wholes in them that appear that the ropes go through? Right? Also the pads have one metal grommet in each pad- like a ring- off to one side of the pad- what is this for? So the wicks go thru the pads? or thru the pan then the wholes in the rocker? This is why? I also thing when I adjusted the valves that it was together wrong when I took it apart. Anyway...I want to do this right. Thanks.
