ORC roll p[in size??
old
So I picked up a roll pin today for the ORC I plan to put on the Allis C. I got a 5/16X2 inch is that correct?? It will be a pain to put on so I prefer knowing I have it right instead of having to crawl under the rear of it to install and find out if is wrong.
Thanks
Old Try a bolt first to check the hole size. Then you can get the roll pin for a few thousandths bigger or for that size hole as you choose. Then the Oc should be easy to check with any pin that will fit in the hole of the OC to check for turning.
