3020 speed gears
Kory1998
Has any one ever seen or had a main speed gear strip out from the differential drive collar or vise versa went and look at a neighbors 3020 and he said that it stripped it off where the little teeth side marks are, I think he is fulll of it idk I could see the collar where first before the gear.
(quoted from post at 00:34:19 01/09/19) Has any one ever seen or had a main speed gear strip out from the differential drive collar or vise versa went and look at a neighbors 3020 and he said that it stripped it off where the little teeth side marks are, I think he is fulll of it idk I could see the collar where first before the gear.
Have a part number for a main speed gear so we can all look it up and find out what they are ?
Yes on the bottom shaft where the shifter collar shifter over
Speed gears like 1&3 2&5 ,4&7,6&8
Gears on bottom differential drive shaft.
(quoted from post at 10:53:26 01/09/19) Yes on the bottom shaft where the shifter collar shifter over
Cam R33443, Cam AA74078 and Shaft(s) AR31903 ???
https://partscatalog.deere.com/jdrc/sidebyside/equipment/76112/referrer/search/pgId/210610
