Goose
Does anyone know where ground wires would be in the wiring on an '07 Chrysler T&C? Just glancing around under the hood, I didn't see any.
It's doing strange things that lead me to believe there's a loose/bad ground connection somewhere.
The tire light will flash and a message "Service Tire System Soon" will show on the display at random and then go away. Also, the ABS light is on and no ABS codes are set. When I started up a bit ago, a message "Message System Not Activated" came on for a few seconds. Whatever the heck that meant. I'd never seen that one before. Sometimes if you drive in rain, or go through a carwash, it will set a code for the ambient air temp sensor. Then if you erase the code, that won't show up again until things get damp again.
It's gotten so I carry an OBDII scanner in the vehicle.
I had an Olds 88 doing outright bizarre things one, and it turned out to be a loose ground inside the left fender.
